Why Dimension Association is failed on Radial Dimension?
Dear Friends,
We try to draw a Radial Dimension by attached code with DIMASSOC = 2. But the Radial Dimension is not Associate with an Object.
Questions:
1. What is the reason behind it? Why the Radial Dimension is failed to Associate with object?
2. If we apply Dim Associate by DIMREASSOCIATE command, the position of Radial Dimension is changed. Why?
I was attached sample project on this mail, Kindly check it.
If there was any mistake or need to add some code reply quickly.
I will wait for your reply.
With Regards,
Vicky.
