dimensioning
in 2D Drafting
Hi there, I am trying to figure out how to efficiently dimension my plans. I work at a planning/surveying company, and produce subdivision plans using BricsCad. Is there a tool to dimension multiple Lots at once, without having to manually measure the length of each boundary? An example of the type of dimensioning that I am talking about is attached. Any help would be much appreciated.
There is nothing built in to do parcel labels like that. You may be able to set up a dimension style that is close, but even so, it won't label multiple parcels at once. Take a look at https://chasmtech.com
Thanks, yeah I remember to use to be a plugin on AutoCAD when I did these drawings back in the day. But will check out your link cheers.
