BOM table does not contain "length" data of components
Hi everyone.
This is my first post in this forum. By the way, welcome everyone.
For a few days I have been trying to create a BOM table that will contain a length parameter (eg the length of a pipe or steel beam). Although the length parameter is added to the components, it is not included in the BOM table. BOM table configuration allows adding columns with description, material, weight, volume and parameters, yet my BOM table does not contain a column with any parameters. I do not know what I'm doing wrong. I will be grateful for any suggestions and comments. Despite searching in "help", tutorials, youtube, etc., I did not find any clues.
  • So, I answered my question myself. None of you could help because the problem was in the Polish language version of Bricscad V18 Platinum (it also occurs in V19). I installed the English version and checked on a simple assembly containing two components. In the English version, I can easily add a column with parameters to the BOM table, it is impossible in the Polish version. Attached are examples.
    I'm really disappointed because I lost a lot of time to solve this problem. All the time I thought that I was doing something wrong, creating constraints and adding parameters, meanwhile the problem was completely somewhere else. Of course, I reported this for technical support.
