Limitation on Roaming days
We have the default setting for 30 days roaming, we try to change this, but it doesn't seem to work. If I select Edit ISV options and then add the following line:
ROAM_MAX_DAYS 27 bricscad
I would expect I wont be able to get a roaming license for 28/29 days....but the server still allows me to do so. However when passing the 30 days it says I need to select a value between 1 or 30. Any suggestions what I'm doing wrong here?
  • Hi Thierry,
    Did you restart the license server after making your edits to the Bricsys.opt file? The server only reads the options during start up, the web interface has an option to re-read/restart.
    If this doesn't work, then check that you've edited the correct options file. There are several different options file that the reprise license manager uses.
    Ralph's latest BricsCAD for AutoCAD Users includes a section in the appendices on network license setup.
    30 days seems quite long. I thought the default was usually 5 days.
    CAD Concepts
