Parametric U bolt
The easiest approach is to _DmDistance3d constrain key subentities to the planes of the WCS. You do not need to add a 'helper' solid at the origin. You will probably need to add a 5th parameter: the radius of the bend. But perhaps that parameter will have a fixed relation with P4.
I am attaching my attempt (I have used V18.2.20), but I think you would learn more if you try this yourself first.
Question: is there a way to constrain 2 circular edges so that they remain co-planar?
Well done Roy.............it had me stumped.
