import multiple DXF files
I would like to be able to import multiple dxf files into 1 sheet as currently I use the import command which is time consuming. Is there any possibility to do this in bricscad like a lisp code or something? I am not a programmer but searched for information and a lisp could be the solution for this. Who can help me with this ?
thanks
Michel
If you were to consider third party software, DotSoft's ToolPac will insert multiple files into the current drawing in one step.
Hi
Thanks but i do not have the pro version of bricscad. A lisp is the only solution I guess.
Michel
Howdy, Stranger!
