BLADE hangs up
When start writing in Cyrillic BLADE is not responding and I have to kill BricsCAD.
Latest BricsCAD 19 Platinum on Windows 10 Pro latest. See the attached video.
https://streamable.com/z45w5
Dear,
yes, there are actually some glitches in BLADE with non-ASCII characters, in different operations;
mainly caused by Scintilla's internal UTF8 character encoding, which causes some trouble in our Unicode environment.Majority of those problems are already fixed internally, and this should be available with V19.2.
You can also send us a support request, with a sample Lisp file, and description which operations you do, so that we can try to reproduce, and to verify whether the particular issue has been fixed.
many greetings !
Howdy, Stranger!
