LIST seems to ignore the Tracking setting
Hello,
I am running some LISTs, and I'd like all my output in one go. I tried changing the Tracking setting as per the command reference, but "Press ENTER to continue...:" seems to appear at the same interval.
Please see an example below.
Either me or Bricscad must be misunderstanding the meaning of the Tracking setting, which is it?
: LI SOrt/Tracking/<Select entities to list>: t Number of command lines to track <4000>: SOrt/Tracking/<Select entities to list>: Opposite Corner: Entities in set: 4 SOrt/Tracking/<Select entities to list>: ---------- Viewport ----------------------------------------------- Handle: 10000694 Current space: Paper Layer: 0 Color: 256 (BYLAYER) Linetype: BYBLOCK Center point: X= 67.786 Y= 76.091 Z= 0.000 Width: 99.516 Height: 128.660 ID: 4 Viewport display: On ---------- Viewport ----------------------------------------------- Handle: 100005DF Current space: Paper Layer: 0 Color: 256 (BYLAYER) Linetype: CONTINUOUS Center point: X= 261.883 Y= 366.111 Z= 0.000 Width: 466.460 Height: 86.692 ID: 2 Viewport display: On ---------- Insert of Block ---------------------------------------- Handle: 100005BB Current space: Paper Layer: ZZ-Border Color: 256 (BYLAYER) Linetype: BYLAYER Block name: nrA0dwgno Description: Insertion point: X= 0.321 Y= -179.141 Z= 0.000 X scale factor: 0.708 Y scale factor: 0.708 Z scale factor: 0.708 Rotation angle: 90°0'0.00" ---------- Block Attribute 1 -------------------------------------- Press ENTER to continue...: Handle: 100005C2 Current space: Paper Layer: ZZ-Title Block
I'm on Bricscad 18.2 if it matters.
The behaviour is by design I think.
The number of lines displayed appears to be "stopped down" to the size of the textscreen Window (as toggled on and off with button). So unless you have an absolutely massive screen - a tracking Setting of 256 or 4000 would make no difference, but a smaller number eg 20 would.0 -
The number of lines displayed appears to be "stopped down" to the size of the textscreen Window (as toggled on and off with button). So unless you have an absolutely massive screen - a tracking Setting of 256 or 4000 would make no difference, but a smaller number eg 20 would.F2 button I meant
Thanks Dan, I tried it just now and it seems to work exactly like you said.
@Mateusz Lawrynowicz said:
Either me or Bricscad must be misunderstanding the meaning of the Tracking setting, which is it?Guess it was me then. The original post was based on a bad understanding of the problem in the first place, (and what I am trying to achieve is quite far from what I actually asked for) so I started a new thread here: forum.bricsys.com/discussion/35661/get-all-output-from-list-without-having-to-press-enter-to-continue
Your input would be very welcome.0
