ORTHO mode not toggling
Version 19.1.10 (x64) revision 58927
Ortho mode does not toggle on/off. The Status Bar "Ortho" changes as it should. When Ortho is off, if I Ctrl+Shift+RightMouseButton, it only pans in 1 direction at a time (either horizontal or vertical). I cannot pan diagonally.
I've never had this problem with any previous versions. I've looked at all the Settings I could find for Ortho (and changed a few just to see if it helped - it did not).
Anyone else having this problem?
  • UPDATE:
    After filing a support request, and several back-and-forth email exchanges, I have an answer.
    The keyboard combination for the unconstrained PAN command was, prior to V19, Ctl+Shift+RtMouseButton.
    In V19 Bricsys changed that keyboard combination to "orthogonal constrained Pan"! To enable unconstrained Pan, hold down Ctl+Shift+RtMouseButton, then release the Shift key.
    According to Bricsys there is no way to change the keyboard combination back to unconstrained Pan.
