How do I dissociate a drawing from a sheet set ?
in 2D Drafting
Hi
The drawing is not in the sheet set. Rather, I copied a drawing to reuse and the original drawing was in the sheet set.
Now when I open the new drawing the sheet set opens up and I have to close it.
It is getting kind of annoying, so I was wondering if there is a way to tell the drawing to stop opening that sheet set every time?
You can unlink the sheet set association from DWGPROPS . See the button on the Sheet Set tab.
CAD ConceptsCome to the Australasia BricsCAD Conference
