autoload a partial CUI
Hello,
How can i config bricscad to autoload a partial CUI?
A partial CUI file is like an xref'd DWG file. It's not a different type of CUI file, just as an xref'd file is not a different type of DWG file. It's only "partial" or "xref" because it has been attached to or externally referenced in another file. When you open a DWG file that contains an external reference to another DWG file, that xref'd file is automatically opened inside the first; and when you load a "main" CUI file that has another CUI file attached to it as a "partial," that partial file is automatically loaded as part of the main file.
