"BIMMY" Options within Components
I think that will happen by the 3D Constraints you apply,
Probably these need correct naming or setting for edibility.I assume it may be the Clip Volume Geometry settings which
hold the overall Length/Width info (?) while the actual Window
Geometries are constraint from that.I would start from a Window file duplicate.
There is also a Video on YouTube Bricsys which shows how
such an object gets built and setup.0 -
AFAIK a Shape user cannot create parametric components.
Ah, did not realize the Sub Forum ...
@Roy Klein Gebbinck said:
AFAIK a Shape user cannot create parametric components.Can they be created in a more "advanced" DWG system?
You will need: BC Platinum, BC BIM or BC Mechanical.
I know this is the "wrong" place for this question - but can they be done with AutoCAD?
You may be able to create a static BIM_SUBTRACT component in AC, but 3D parametric components are unique to BricsCAD.
Note: I think that all solids inside components are subtracted from the parent object when using the _BimInsert command. So you are not restricted to using the BIM_SUBTRACT layer.0
