Can't copy-clip between drawing files?
I need to base a site plan off of a survey dwg file that was provided by the client; this is routine for me and I've never had a problem... until now. For some reason when I try to copy-clip something from the survey dwg file, I get this:
"Not allowed for this proxy: < ObjectDBX Classes - "AcDbAssocPersSubentManager" > (31EC)"
...and nothing is added to the clipboard. I've tried exploding, saving as another drawing, saving the drawing down to an earlier version, and exporting to dxf...
Thoughts?
Are you using the COPY command or the COPYBASE command? I use COPYBASE to copy between drawings.
Have you tried _SaveAsR12? Note: this will remove a lot of modern features from the dwg.
@ Casey Fry
Please send in a support request and attach the drawing you are having the issue with. Our analysts will be glad to investigate.0
