not all panels are enabled when setting a AcadApplication visible
I create an AcacApplication by COM,
acAppComObj = (AcadApplication)Activator.CreateInstance(Type.GetTypeFromProgID(strProgId), true);
then I open an existing drawing (with sheet metal part that is smconverted)
acAppComObj .Documents.Open(povDwgFile);
and set the application visible.
acAppComObj .Visible = true;
But the Mechanical browser often stays disabled (see attached screenshot) . Am I doing something wrong or should I call some specific refresh?
I'm using BricsCAD V19.2 now.
For your info,
I managed to get the panels activated when I call folowing line after setting the app visible:
acAppComObj .RunCommand("_redrawall");But nevertheless this should not be needed in my opinion.
Try changing the Active property of the dwg to true.
Thanks for this solution, Roy. Thats exactly the case i got while displaying OpenDCL panels.
The activate property of the current document will fix this issue.Martin
@Martin Drese
Thanks for confirming this can be effective.Pity @KarelVergauwe can't be bothered to respond.
Sorry,
did not find the time to reflect on this.I tried both ActiveDocument.Activate() and ActiveDocument.Active = true but it did not enable the panel.
I stick with the _redrawall lisp for now.
What I did found out was that any lisp / command activates the panel
@KarelVergauwe
Thanks for getting back to us and sharing your findings. It may be worth sending in a Support Request regarding this issue.0
