Multileader, can't add text
I'm following the exercise, "Add and modify multileaders", which can be found here: https://lessons.bricsys.com/courses/381961/lectures/5835161
On step 5, it says, "In the multiline text editor, type STRAP TIE"
I see a kind of editor, and even though I press keyboard keys, nothing happens. If I click somewhere else on the drawing at that point, then the multileader loses focus. I can then click on the multileader, and the properties editor appears on the right of the screen for it. There is a field, "contents," and when I try to put something in there, the text properties box reappears and it looks like I'm in the editor session again, but I can't enter anything.
Any help would be great with this.
You can edit the mleader by two ways.
1. double click mleader text
2. type "ddedit" at command line. and select mleader0
