Problem with toolbars and workspaces in 19
When our startup code detects that our menu does not exists (typically only the first time) we load it and setup out ribbon bar, menu, and toolbars. Then we save a workspace. Initially everything is correct. If I go into the customize command, the workspace shows the toolbars. But as soon as I close the customize dialog, either by OK or cancel, I lose all my toolbars and if I go back into it, the workspace shows no toolbars at all.
If I unload everything and let my code recreated it again, everything is fine until I shut down Bricscad and restart, then I get no toolbars again. It seems that workspaces are not saving toolbar information at all. This was working in 17 and 18.
Has something changed with 19? Can a workspace be included in, and used from, a partial menu yet?
Another thing I found. If I go into the customize command and manually add the toolbars to my workspace, they are gone as soon as I exit the dialog.
