Command history
in 2D Drafting
there is transparent commad history. I don't want that. Can you help me?
CRTL+9 should bring the command line. Move it then to the prefered position.
OK?
Regards
Wolfgang0 -
When the command line is closed the CLIPROMPTLINES system variable controls the number of command history lines that display transparently. If you set CLIPROMPTLINES=0, the feature is disabled.
Please remember you can toggle the command line on/off by double clicking the left hand side of the Status bar.2 -
^ very nice tips !
it works. thank you
thanks
