BIM Connect - Connect with nearest
Just want to say the improvements for v10 are absolutely gorgeous.
Now things (BIM in Bricscad) start to make sense - lot of sense.
Looks like I can finally BIMCONNECT two Walls,
although they exceed their connection area,
without the need to each time push their End Faces back behind their
connection area before using BIMCONNECT.
Same for TCONNECT.
I can now adjust a Wall to butt a Column,
although the Wall already exceeded into the Column,
without the need to each time push their End Face back behind their
That brings back a lot of fun to work.
