Bim Generate Section Crashes BricsCAD
I've got my templates in a server, so to create a sheet brics reads the server. I thought that it would be the problem when I BIM Generate Section. Is there anyone with this problem or experimented that issue? I'm using the last version V19.2.07 (x64) on Win10. I've tried already with the templates in the desktop and still crashes.
Thanks for any support.
Is there something related with the templates allocated files as I've just realized there's a BIM Template in the Options which should be the same template as in the Files - Template in the Options? This may cause crashing issue?
Dear Maurillo
Can you file a support request? This is the best procedure to get your problem fixed. Go to https://www.bricsys.com/en-intl/support/ and follow the instructions.0
