Cannot create a Region from 3D Polyline after Z-Value has been changend.
I want to convert a 3D-Polyline into a Region. This works fine, as long as I don't change the Z-Values after the Line has been drawn. Once, I change a Z-Value, the Region cannot be created.
Is there a way to create a Region after the Z-value has been changed? Or is it possible to change the Z-Value of a Cornerpoint of a region?
Thanks
I understand Regions as 2D Objects that have to be planar.
So I don't think pulling 1 corner up would work (?)While I had no problems converting 3DFaces or Polylines,
located and rotated free in 3D Space, to Regions - as long
as they are planar.0 -
as they are planar.Thanks. I don't think that this is the problem. If the 3D-Polyline is created with the exact same values that I changed it to in the first place, I can convert it. However, if I change the Z-value afterwards it cannot not be created. Event though, the result should be the same region.
Hmmh,
I just tried.
I draw a Polyline on Layer Plane.
I copy the Polyline.
I move the copy in Z.I still can convert both Polylines into Regions.
Same for 3DFaces.
Just when I distort a 3DFace by pulling a corner up,
it will no more convert into a region.0
