AcCoreConsole in Bricscad
Hi
Is there any similar tool to Autocad AcCoreConsole in Bricscad ? Its a application to run scripts without opening files. I want to write a script that use command 'wblock' on several dwg files in the folder without opening this files.
It's not exactly the same thing, but you can run BricsCAD invisibly in the background by specifying the /automation switch at the command line.
@Owen Wengerd said:
It's not exactly the same thing, but you can run BricsCAD invisibly in the background by specifying the /automation switch at the command line.Its very interesting but I need more detail. Could you type some example or link to bricscad help or to good book? I need only help with run in invisible mode
Howdy, Stranger!
