SQL Server Connectivity
Hello!
Is there an out of the box method to connect linear and point elements to data tables in SQL server? If so, can you update the SQL table from BricsCAD?
Any help on this would be greatly appreciated!! Thanks
May I follow up about this matter as well on what's the process. TIA
Any luck here? this seems interesting.
Basically merging the SQL networking library with with BriscCAD library and creating an application for SQL import and export.
What language, there’s SQLite for AutoLisp here https://www.theswamp.org/index.php?topic=28286.0
Python, duckdb is the new thing, it’s wicked fast http:\\forum.bricsys.com/discussion/39022/using-python-s-data-science-tools-for-data-extraction
