Tiny buttons on high dpi (4K) screens
There is a scaling issue on high dpi (4K) screens.
The global display scaling in Ubuntu/Gnome only affects the font sizes in BricsCAD.
I have to switch to the largest Icon size, that's ok for the toolboxes, but all other GUI elements like spinbuttons, menu icons, the navigation elements in the model/layout tabs area and icons in panels are extremly small.
Is there any way to enlarge these GUI elements, too?
Even in the Windows Version there are some UI Elements
that ignore scaling. Like the first row of header text boxes in
Layer Palette.
On Mac I have a few Problems with DYNDIM number boxes.On Linux it is a bit worse.
AFAIK I had even Problems with Fonts or corresponding boxes
when in standard non-scaled low res Mode on a 30" 2560x1600.
Maybe there are even different behaviors between Gnome/KDE/XFCE
Desktop Environments (?)0
