How to define the sheet set for a section plan drawing?
How do we define the sheet set for a section plan drawing?
I have made a model and a section plane.
I generate that section and a sheet set ( with the name of the file) and a drawing is created.
After that I filled the project brower data.
Then, when I generate the section drawings a new sheet is created with the name of the project.
We end up with two sheet sets:
modelfilename.dst
projectbrowsername.dst
How do I define the default sheet set to be the first one?
I think you have to set the projectname variable, so bricscad recognizes what project the file belongs to. Just type "projectname" and name it..
@Lukas Fertig said:
I think you have to set the projectname variable, so bricscad recognizes what project the file belongs to. Just type "projectname" and name it..Thanks, I will check it.
