Control visibility by parameters
I'm creating some parametric blocks but I could not find a way to turn on/off objects by parameters. I would like to have the possibility do chose by setting a parameter if an object, like a hole for exemple, is shown or not in the block. Am I just missing something, or is this not yet implemented in BricsCAD?
If you haven't solved this yet, try the suppress parameter
Howdy, Stranger!
