Restore objects after slice
How do I restore my objects after using the SLICE command? I created a helix and used SLICE to look a cross section. Which command will restore the missing portion of my helix?
_undo should work.
Another option: when you slice, choose the Both option and do _hideobjects rather than deleting the interfering part.
Better than either, though, would be to do a _sectionplane. It's much more flexible.
Thanks, I missed a_sectionplane part
