Access Segments of 3DPolyline
I want to create a text specifying the slope of each segment of 3D Polyline. I can access the points of the line just fine by looping through the PolylineVertex3d objects of the line.
However, now I want to access each segment of the polyline, to get the z-value of the start and endpoint as well as the length and the angle. Is there a way to loop through the segments of the 3D Polyline?
Thanks!
Yes, but what language do you want to use ?
