Get all blocks inside a block
Hello everybody,
Im quit new to AutoCad and now i want do get a collection of all blocks wich are inside another block in my C#/.NET Plugin. I found a way to get all blocks in a Polyline (thanks to _gile https://forums.autodesk.com/t5/net/find-block-inside-a-polyline/td-p/7586489).
Now i want to apply the same principle to the outline of a specific block.
Example:
Block Edit View of Block Room A
Example i want to get de Blocks marked with pink.
So my idea is to somhow geht de outlining lines of the block to form a new poly line and then use the solution from _gile mentioned above. I have acces to all room block in my file as they are all on the same layer.
Thanks for your help!
Hello,
please define "block in block"
-> geometric / location
OR
Datastructure -> BlockReferences inside BlockTableRecord?~~lookat SelectionSet and TypedFilter. Using TypedFilter you can filter all blocks ( dxfcode 0 "Insert") and (dxfcode 8 layername)
=> GetAll(filter) creates the SelectionSet. (no polyline bounds) or use GetSElection(filter)
Loop the SelectionSet , get the OID of the selected Obect AND/OR Convert the SeletionSet to ObjectIdCollection~~0
