Forum Tools - Quickly add links to HELP + Signature tool
Attach a script (see zip) I created using AutoHotkey that forum users may find useful. The script contains 3 tools:
Command Reference
CTRL + M
Will wrap the selected text with a focused search of the online command reference e.g.
Help Search
CTRL + J
Will wrap the selected text with a general search of the the BricsCAD Help e.g.
Forum Signature
Typing "FS" will replace the text with a forum signature. e.g
Joe Blogs
BricsCAD V19 Ultimate
Joe Inventions
You can customise the signature detail etc. by changing the global variables in a text editor
;FORUM SIGNATURE global ClosingRemark := "Regards" global Name := "Joe Blogs" ;BricsCAD Version & Type ; Will be omitted if blank "" global BricsCADVer := "19 Ultimate" ;Company & URL details. Both need to be filled to use. ; Will be omitted if blank "" global CompanyName := "Joe Inventions" global CompanyURL := "https://forum.bricsys.com" ;BRICSCAD HELP ;Base URL to BricsCAD online help global URLbase := "https://help.bricsys.com/hc/en-us/search?query=" ;COMMAND Category suffix. Autoload=true automatically loads global CommandURLsuffix := "&category=360000679494&autoload=true" ;Command tooltip description global CommandURLDesc := "Search the BricsCAD Command Reference for HELP on: " ;General search tooltip description global SearchURLDesc := "Search the BricsCAD HELP for: "
It would be nice if this functionality was built-in to the forum. I think it is useful to provide links to the HELP where possible in a post. It allows the poster to be succinct in their answer while providing a way to expand with more detail for those that require it. By doing so it may also lead to a better HELP source.
I'm sure that someone who knows Autohotkey could do a better job of it than me.
CAD Concepts
