point numer in attributes
Hello everybody,
I work in surveying and we often need selected points with point number.
Is it possible to assign a point number to individual points? I work with Brics Cad Pro.
Greetings Nicola
In stock BricsCAD you would need to create a block definition that includes your point attribute. You may add a description and elevation attribute as well. You would then insert these at the point locations and fill in the attributes at that time. If you were to consider third party add-ons, DotSoft's MapWorks is a low cost package (running inside BricsCAD Pro) that will help with points as well as other survey related tasks.
