Equation parameter won’t display in BOM
Hi all,
I’m totally new in Bricscad environment but I’m trying to push forward with learning.
Unfortunately I’ve encounter some strange issue.
I’ve created a solid (cylinder) with parametric function to control radius and length of object.
To get the cylinder surface I’ve made equation of 2*Pi*r where r I dreaded from parameter of radius let’s call it radius_1.
In values I see that score I’m getting is ok but little lock on a side is grayed out.
I’m changing expression from auto to on and lock is getting orange - which should mean it’s all fine and parameter will be displayed in properties when I will insert my component to model.
I’ve tried everything and I can’t get it working.
My goal is to have this parameter available for BmBom as it is essential for further detailing.
Did anybody had similar issue?
