3D view to certain face
Hi everyone, is it possible to set a view to a face of a solid?
Do the following
Run the UCS command and use the Face option, select the face of the solid and confirm the UCS which is aligned to the selected face.
Run the PLAN command and confirm the default (= current UCS): the plan view aligns with the XY plane of the current ucs, which is the face of the solid.0 -
When UCSFOLLOW=ON the plan view of the UCS is restored automatically (no need to run the PLAN command).
