BricsCAD is using only CPU, not GPU
Phil
edited September 2019 in Other
Hello everyone,
I have a HP Z240 Workstation with Nvidia Quadro P4000. I figured out that only the CPU is used for rendering. I installed the latest drivers but still the CPU is used.
What can I do that BricsCAD finally use the GPU?
Thank you for your help!
Phil
Edit: My BricsCAD version is Version 17.2.12 (x64) revision 49652
  • Try checking RENDERUSINGHARDWARE
  • Hello Tom,
    The parameter is on "1".
  • Not sure which - try the other setting
  • "1" is prefer hardware.
    I tried it anyway, but no changes.
  • Dear Phil,
    try REDSDKINFO, see what it reports, can give a hint about the NVidia driver;
    you might also send that REDSDKINFO output to our support system.
    Sometimes, using an older driver did effectively help, especially for those "professional CAD" graphic cards (which is a kind of mystery anyway, such was valid 10...20 years ago - but actually it is much better to uase a fast, midrange...highend standard "Gamer" graphics card).
    many greetings !
  • Please note that the GPU will only be used for visual styles other than 2dWireframe, that is: the 'rendered' visual styles
  • If you are talking about rendering a view (Raytracing)
    AFAIK it is CPU only.
    (And doesn't use all of my cores)
    Theoretically REDSDK would offers more advanced Renderers with
    global illumination and a real time solution for GPU.
    Maybe in the future.
  • @Torsten Moses said:
    those "professional CAD" graphic cards ... was valid 10...20 years ago - but actually it is much better to uase a fast, midrange...highend standard "Gamer" graphics card
    Have I edited that correctly? Do you really mean that for Brics we needn't buy a Quadro machine, instead a gamer machine with several x faster graphics for the same money?
  • Hans De Backer
    Midrange cards will do absolutely fine, the bottleneck for dwg display operations is almost always at the CPU side, not the GPU, so there's no point in buying the fastest GPU on the planet.
    Nor is there any benefit from buying a Quadro: yes, it can handle double precision coordinates vs single precision for most other cards, but this feature is not used.
  • Is there any recommendation for NVidia GTX/RTX Cards under Bricscad,
    if we should install the newer Gaming Driver vs the Content Creator version ?
  • No recommendation for any specific cards.
  • Phil
    Does that mean that my workstation actually is much overdesigned?
    My boss bought it because I should draw our project in 3D so we have the option to make nice pictures for presentations or even videos.
    So I started to draw everything in 3D and realized that BricsCAD became slower and slower...
    Edit: The output from REDSDKINFO:
    RedSDK version: 4.2 (build 4)
    RenderUsingHardware: Hybrid hardware/software mode with preferred hardware rendering.
    OpenGL window creation succeeded.
    Operating system: Win_seven64
    Desktop composition (Aero) is enabled.
    Local GPU:
    GPU information:
    name: 'Unknown NVIDIA graphics adapter'
    chipset: ''
    class: 'HW_NVIDIA_GENERIC'
    asicID: '0x1bb1'
    vendorID: '0x10de'
    recommended driver: unknown
    Installed driver:
    driver: 'NVIDIA Forceware 431.70'
    dll version: ''
    This driver is newer than all internal known revisions.
    validation: 'Ok, newer'
    Selected GPU (created for GPU check):
    Chipset: HW_NVIDIA_G400
    Vendor: NVIDIA Corporation ( IsNVidia )
    OpenGL version: 4.6.0 NVIDIA 431.70
    Renderer: Quadro P4000/PCIe/SSE2
    Would that apply to Autocad too or is it part of Brics' cleverness?
  • If you make render nice images or films - by using 3DSMax -
    it will profit from Quadro Cards with a special driver.
    Most Autocad Apps are supported.
    Same is true for Catia, Siemens NX and such Apps.
    But the majority of typical CAD and 3D Apps don't make use
    of Pro GPU features or special drivers.
    For those Apps that are supported,
    even older and or weaker pro GPU models make 3D Viewports
    run smoothly.
    In the past, many typical CAD features like full screen cross hair cursors,
    panels over 3D Views and such things where not included in gaming
    cards and drivers, so ran slower in Software by CPU.
    While Pro Cards offered faster hardware acceleration in GPU and by
    Drivers.
    Nowadays, many of these features are needed for more complicated
    games too, so went in Gaming GPU Hardware and Drivers also.
    So as long you are not using such pro GPU supported Software,
    Pro cards aren't very interesting because of their higher prices.
  • @Phil,
    the CPU is more important, 3D modeling operations are executed on the CPU, not the GPU.
    3D CAD is about creating, editing, sectioning, quantity calculation, etc... of models, not only displaying and walking through them.
    Better not tell my boss...
  • Tom Foster
    For several years I had understood that Microstation had 'broken the iron rule' in not needing pro graphics cards, since it switchred from OpenGL to Direct3D, but that any CAD still using OpenGL would not have all the features supported except by pro graphics.
    It is not bad to buy a workstation with 24/7 support and all such things.
    You often can configure Pro cards only.
    Pro cards are often the only way to get more VRAM, if you need.
    Maybe they have cherry picked chips, better VRMs and lower TDP, ...
    They are tested with your workstation.
    P4000 is (was) a 1000 $ card, is still Pascal architecture.
    You just would have got a comparable GTX for 500 $ and maybe the same
    performance in Bricscad.
    But it would fly in ProEngineer and those Apps.
    Gaming cards and Drivers are optimized for high frame rates in games.
    That was true at that time. 90ies to early 00's (?)
    Yes, Microstation switched from OpenGL to full Windows only and DirectX.
    DirectX was also the 3D Api for games, so all gaming GPUs and Drivers
    supported DirectX standards, hence perfect for Microstation CAD usage.
    OpenGL also improved over time.
    And every recent gaming card supports newest OpenGL, DirectX and maybe
    Vulkan and Metal. So it is fine if an CAD Apps uses OpenGL, without exotic
    legacy OpenGL calls. And they recommend gaming cards as they test their
    Software against mainstream gaming cards and not exotic Pro cards.
    But if you use a Software like ProE, NX or some Autodesk Products,
    likely a cheap P1000 will run circles around a GTX 1080TI in their
    3D Viewport.
  • Thanks to all for the information.
    Next time I will request a Xeon instead of i7.
    I'm only working with BricsCAD, so that seems the better solution.
  • I would request an AMD Threadripper :)
    Here is a nice Video that shows current state of Pro GPU
    and Xeon vs mainstream CPU usefulness.
    And that Pro GPUs may be great - if you use such supported 3D Apps.
    https://www.youtube.com/watch?v=G-90qEJAVkU
