Ongoing problems with LISP that creates fields
I have had this ongoing problem with trying to use LISP routines that will call out the length of a polyline. Most recently, I've tried one by Lee Mac, and his programs are all well done, so I assume the problem is something at my end.
Specifically, I am trying his LengthAreaFieldV1-3.lsp utility, which prompts the user to select an object(s) and then a text (or other similar) entity which is changed to show the length of the objects you chose with a field. [ http://www.lee-mac.com/lengthfield.html ]
In my case, I tried it on a polyline, and then the text of a leader I had created with the word "length". [Edit... I see now that my choice of the text "length" was not a wise one, since the phrase ".length" is how such a field should normally end, since it calls out the length. If I had used "test", the word "test" would simply have been replaced. ]
The results are below. Note that it is this code that shows, not the actual length.
%%).Length
Similar utilities from other sources generate similar results. Any ideas what the problem might be?
-Joe
Thanks Roy, I am sure that is the issue, since I am on v14.
-Joe
