Structure Panel not showing search window
How do I get a Search box in the Structure Panel?
This article has it:
https://blog.bricsys.com/bricscad-journey-selection-methods/
This doesn't:
https://help.bricsys.com/hc/en-us/articles/360006428794-The-Structure-Panel
If it does what I think then I need it desperately: I have a spreadsheet with handles for Objects identified for QA checks, and I need to select them quickly, I expect I can copy and paste the handle.
How do I get Structure Panel to show the search window/box?
This search field was added in V19.
If your BricsCAD version is older, you could create a structure panel configuration to sort all entities by handle, which would also allow to very quickly find an entity by looking up its handle. The definition of such config file is as easy as it gets, just specify that a Sort should be done by Handle, as in the attached screenshot.
Have a nice day.0
