Import of walls with compositions go wrong in Revit
When I make a ifc of walls, windows and doors, and I open it in Revit, the windows and doors are tilted in Revit.
This only happens when I use a wall with compositions.
In the attached dwg-file I have two walls, one with compositions, one without compositions.
In the attached jpg-file you can see the result in Revit.
The ifc-viewers Solibri, Tekla and BIM Vision show both walls, windows and doors correct !
I use Windows 10, BricsCAD BIM 19.2.14 and Revit 2020.
The used composition, window and door are from the BricsCAD library.
€katrein
Can you please file a support request and add a sample model?
See https://www.bricsys.com/en-intl/support/ for instructions.0 -
Louis,
A drawing Test Composites 1.dwg was attached.
But I already found a solution for the tilting of windows in the Settings: Export multi-ply elements as aggregated elements.
But now I found a new problem: In Revit window-openings ar not shown when:
- 2 or more walls are connected with a miter-connection, AND
- The walls have compositions, AND
- The walls are connected to a roof with a slope.
Only when all three conditions are met the problem in Revit occurs.
I attached a IFC file. Two roofs were deleted, but that dit not solve the problem.0 -
Hi Katrein
This forum is not the right place to report possible bugs in the software. In order to get them properly addressed a support request is needed.0
