Startup Error Message on Vertical Product
Could this error be caused by BriscCAD? This is generated inside CADWorx.
Your vertical may need to make changes to accommodate the new startup option (which I hate). Previous versions started with a new blank drawing ready to go (editor fully initialized). Consider trying different values for the STARTUP system variable.
Howdy, Stranger!
