Multileader creation issue with vlax-put TextRightAttachmentType
After many attempts to get my Multileader Style creation algoitm to work (v19.2) I discovered that the integer value for the TextRightAttachmentType property is not the same as AutoCAD.
The integer value I used to get the TextRightAttachmentType acAttachmentMiddleOfBottom in AutoCAD is 5.
In BricsCAD it appears to be 3.
(vlax-put MLeaderStyle 'TextRightAttachmentType 3)
Anyone else notice this? Or am i doing something wrong?
-steve
Hello GraceS,
from testing in V19 : (print acAttachmentMiddleOfBottom)
5 5
so the declaration of the alignment symbolic names seems correct;
but as it seems, it is the MLeader code itself which creates a wrogn MLeader layout then.Have you tried with V20 version (a number of defects related to MLeader entities are fixed) ?
If the issue still happens with V20, using the correct + intended "acAttachmentMiddleOfBottom", then it seems best to send us a SupportReqeust (maybe with a code snippet + sample dwg), so that we can investigate and fix.many greetings !
Thanks for the response!
I have been using this code snippet in the autodesk CAD product for years and just now trying to move to BricsCAD:
(vlax-put MLeaderStyle 'TextAlignmentType 0)
(vlax-put MLeaderStyle 'TextAngleType 1)
(vlax-put MLeaderStyle 'TextHeight (* 2.5 dimscale))
(vlax-put MLeaderStyle 'TextLeftAttachmentType 1)
;(vlax-put MLeaderStyle 'TextRightAttachmentType 5);Autocad Proper setting
(vlax-put MLeaderStyle 'TextRightAttachmentType 3);Works in BricsCAD
(vlax-put MLeaderStyle 'TextString "")
(vlax-put MLeaderStyle 'TextStyle MLTextStyle)
(vla-put-colorindex MLColor 256)
(vlax-put MLeaderStyle 'TextColor MLColor)
(vlax-put MLeaderStyle 'ContentType 2)
... etc.
I did try using the symbolic name, acAttachmentMiddleOfBottom in the code but it still gave me "Underline Bottom Line" when the style was created.
Everything else appears fine.I have confirmed that all of the symbolic names return the same integer in both AutoCAD 2020 and BricsCAD v19
(print acAttachmentAllLine) 8
(print acAttachmentBottomLine) 7
(print acAttachmentBottomOfBottom) 6
(print acAttachmentBottomOfTop) 2
(print acAttachmentBottomOfTopLine) 3
(print acAttachmentMiddle) 4
(print acAttachmentMiddleOfBottom) 5
(print acAttachmentMiddleOfTop) 1
(print acAttachmentTopOfTop) 0I have just requested v20. We'll see how it goes.
-steve0 -
I have just tested with v20.
Still works the same as v19.
For the TextRightAttachmentType, I still have to use the incorrect acAttachmentBottomOfTopLine symbol to achieve the acAttachmentMiddleOfBottom appearance in the new multileader style.
(That's good I guess, as I do not have to use different settings for different BricsCAD versions)
-steve0 -
Hello GraceS,
thanks for your feedback ... in fact, this sounds as when there is a defect in our underlying ODA Teigha core system, operation in opposite way, based on the acXXX symbolic constants (enum values).So indeed best, if you could make a small sample (some Lisp code + a small dwg file) and send us this as a SupportRequest ?
Then we can investigate and fix the behaviour ...many gretings & thanks in advance !
