V20 VP-layers
Hi, So I've designed 2 simple walls with steps. I have 2, left and right. So I created vport for front, side, top view and 3D. In the vp-layers I froze one layer which is my R column. When I create other vport, I try now to freeze the left column but then they both disappear. What am I doing wrong?
You're using the VP-Freeze column in the Layers dialog, not the Freeze column, right? That column only appears in the dialog when you're on a layout tab.
It freezes layers only in the viewport you're currently working inside of. But if you use it while you're not inside a viewport, it applies that setting to all the viewports in the layout tab that you're on. It sounds like that's what's causing your problem.
Yes using the VP freeze on the far right0
