Customising the Ribbon
I think I'm being stupid here but if I insert a panel (Zoom) to the Home tab on the ribbon, it appears fine but does not re-appear when I re-start BricsCAD. I don't customize the ribbon much so don't know if this is something affecting v20.1.04 (x64) that I have just installed, or if I am missing a step. The default.cui file in the Roaming folder structure looks like it is being updated but could it be loading a different .cui somehow?
Help appreciated.
Jamie
Not a different cui, but a different workspace. Did you restart BricsCAD in the same workspace?
Hello Louis. As far as I know, yes. It's just the Drafting workspace.
Regards
Jamie0 -
There seems to be a few issues affecting me with v20 so I've uninstalled it for now. e.g. loading multiple files at the same time fails with access errors to the .cui
