V20 set/get variables
I am used to set variables with an _ so it's language irrelevant.
I do it like this on several places and ways:
in script as: _setvar _variable VALUE or _variable VALUE
in lisp as (_setvar "_variable" VALUE) and (_getvar "_variable")
in COM (C#) as: AcadApplication.ActiveDocument.SetVariable("_variable", 1);
It now seems that in V20 you should no longer use the _ in the variable name.
the _variable VALUE as command still works, but all other no longer work.
Was this done intentionally? Is it described anywhere?
Karel
- I also see inconsistency: For example the difference between saveformat and vernum:
 - (getvar "saveformat")
4 - (getvar "_saveformat")
nil - (getvar "vernum")
nil - (getvar "_vernum")
"20.1.01 (UNICODE)"
For vernum, the _ is needed. Checking the settings dialog I see that saveformat has no _, and _vernum does (looking at the variable name in the lower left corner of the settings dialog)
Dear Karel,
- system variables are never translated, so the underscore _ is not necessary at all, especially not in API level calls (setvar(getvar "saveformat")
 - when using without API, like on your script file, the variable name is entered as COMMAND ... and here, the _ is used to distinguihs "localised" vs. "global(english)" command name - which is identical for system variables (as not being translated)
 - there are a very few system variables, which have the underscore as part of their native name like "_vernum" ... I think there are 2,3 more system variables using the underscore as native name part, but rarely used
In short - via APIs (Lisp/NET etc.), use the plain system variable name ...
in scripts, underscore can be used (but has no effect) - so even in scripts, using (setvar/getvar ...) is the better approach :-)man ygreetings !
Torsten,
thanks for the clarification!
Karel
