Viewport Scale
Good Sunday afternoon,
I currently apply the scale of a viewport by clicking on the edge of the viewport and opening "properties" and setting the scale there. I would rather have a tool I can put on the "View" toolbar adjacent to the "Viewport" tool. Is there such a tool that would offer a fly-out with a list of all available scales or perhaps just a better way than I'm using now?
All suggestions will be greatly appreciated.
Thanks,
Russell
You could make your own custom tool that includes whatever scales you want.
It's best to do it in a custom "partial" CUI file, which is attached to the main CUI file.
That's so you won't lose it when you install a new version of Brics with a new CUI file.The attached file shows an example of how I do it, using the SVP custom command below.
I do it as a pull-down menu, but I think toolbar items are defined in a similar way.
For each item, I show the actual scale factor, then the scale's name, then the text size for that scale.
So, in addition to being a bunch of commands, it's also a handy pull-down chart of useful information.;;; Viewport scale factor command (works even if viewport is locked) ;;; Create a custom menu or sub-menu or Partial CUI file called "Scale" ;;; and fill it with custom tools created in this format: ;;; Title: 1" = 20' (240) Command: SVP;240 ;;; ------------------------------------------------------------------------------ (defun c:SVP (/ NotPS NoSS SF SFI ss1 N vpN ObjN) (defun NotPS () (prompt "\nOnly works in Paperspace. ") (exit) ) (if (> (getvar "CVPORT") 1) (NotPS) ) ;; CVport: Pspace=1; Mspace=2; Vport=2+ (initget 7) ; prevents Negative, Zero, or Null input (setq SF (getreal "Scale Factor: ")) (setq SFI (/ 1.0 SF)) (defun NoSS () (princ "\nNo viewport selected. ") (exit) ) (setq ss1 (ssget '((0 . "VIEWPORT")) ) ) ; selection filtered - viewports only (if (not ss1) (NoSS)) (setq N 0) (while (< N (sslength ss1) ) (setq vpN (ssname ss1 N) ) (setq ObjN (vlax-ename->vla-object vpN)) (Vla-Put-CustomScale ObjN SFI) (setq N (+ N 1)) ) ; (sssetfirst nil ss1) )0 -
Thanks Anthony but I'm afraid that's too advanced for the knowledge I have.
Thanks for taking the time to help,
Russell0
