IFC export
I have created a simple drawing using BIM profiles and then exported to an IFC file using both IFC types (IFC2X3 file & IFC4). I used BIMIFY prior to the export.
I then opened each IFC file in Navisworks and expected to see the BIM data attached (e.g. profile size, length, mass, volume etc) to each profile, however this is not the case.
Can someone explain how I should go about getting that data exported as well. It works on other IFC files from different packages when their files are exported.
TIA
