no zoom after point select
Hello,
For example: when I draw a line from a point, I cannot zoom out with the mouse wheel to another place.
Can I set it up so that it is possible?
Ben
You should be able to do that. The ZOOMWHEEL and ZOOMFACTOR variables control which direction and how fast the wheel zooms, but I don't know of any setting to turn it off. Maybe your mouse software has a setting that affects Bricscad?
Hello ,
I'm using a Apple magic mouss on a Macbook pro .The zoom function works fine until I select a point to draw a line.When I start to draw the line I'm no loger able to zoom with the magic mouse until I make a left click.
With a normal logitech mouse this works fine.
Im using bricscad V20 for mac Beta , but this was also the case in V19.
Kind regards.0
