since i've installed the v20.00 it's impossible to create linetipes with express tools
C:\Program Files\Bricsys\BricsCAD V20 en_US\Express\Express.des
;* bad argument type ; expected at [equal]
any suggestions to fix this please
kind regards,
thomas
I have some problem that looks like it
Can't use Blocktoxref after installing Express tools
command: blocktoxref
; ----- LISP : Call Stack -----
; [0]...C:BLOCKTOXREF
; [1].....ACET-BLOCKTOXREF-UI
; [2].......ACET-UI-TABLE-NAME-GET
; [3].........ACET-UI-TABLE-NAME-GET-DLG
; [4]...........ACET-UI-TABLE-NAME-GET-IS-VALID <<-- ; ; ----- Error around expression ----- ; (STRCASE TBLNAME T) ; in file : ; C:\Program Files\Bricsys\BricsCAD V20 en_US\Express\Express.des ;* bad argument type <2> ; expected at [acet-str-format]
If it's any help. I loaded Express tools for V18 into my V20 and the line tool works fine.
But I don't know if all of the v18 express tools will work in v20.
