Attribute Def Multiple Lines Breaking When opening In AutoCAD
Hello,
I am having a bit of problem with attributes that has multiple lines. Every time i edit a block with multiple linesattributes in BricsCAD or create a new one in BricsCAD then when i open it in AutoCAD, the attribute it self is moved. Attsync does not work because the attribute itself in the block editor is moved. I tried all versions of AutoCAD and BricsCAD and it give me the same result.
Any help would be appreciated.
