V. 20 drawing explorer changes
A changes I noticed in V20 -- would prefer to go back to the V19 behavior and wondering if it is possible:
- In V19, if you type "layer" or "xref" it would bring up the Drawing Explorer with the layer or xref category selected -- then you could select another category instead if you want. But in V20 each of these commands brings up an abbreviated dialog box with fewer options and no way to switch to other categories. Interestingly, if you type "view" in either version the old-style behavior is maintained. Is there any setting that will keep the V19 behavior in all cases?
Also, is there any way to make the icons in the Drawing Explorer dialog box larger? I use a 4K monitor and they are miniscule. This was an issue in V19 as well but with the new dark mode interface they are even harder to see. Can't find a setting for this.
