Is it possible to run this in BricsCAD?
My attempts failed
; Lisp processing cancelled
C:_Data....\user\LayerDirectorV1-9.lsp loading failed.
Would be very welcome to get this started.
Hi Hans,
I have this working in V20 (Windows), the only problem I have is keeping it loaded as V20 keeps switching some of my lisps off.
I load it through my on_doc_load.lsp and in appload.
When I say loaded, Lee has incorporated an LDON and LDOFF within the lisp and it is this that keeps being turmed off.
I have an SR going with the issue.
Can you copy and paste the lisp to the command line and run it in a single drawing to check if it is loading?
Hope that helps.
Right! Something was wrong with a other lisp that caused the first error.
Fixed it and Layerdirector works great now. I finished it with this call.
