Xlist message box too short
Any way to make this (default) messagebox wider?
Dear Hans,
I would like to reconfirm your post,
In AutoCAD there is an xlist.dcl file which control the window size, but in BricsCAD I cannot find anything (v20 and v21).
I hope we get soon this feature.
Best regards,
Gabor -
Its a fairly straight forward dcl and while it does not auto could be changed for a custom version, I check strlen of text lines so change the dcl width = to suit. Maybe change to Alert.
Thank you.
I have also get an other way from Bricsys Team:
"Regarding XLIST command, it comes from express tools so the question should be addressed to the application owner.
Still, please try this: hover the xref nested entity, then press Control key and the rollovertips will show you the nested entity properties."
Howdy, Stranger!
