MText parsing issue
I'm currently using BricsCad v17.2.09 on a late 2015 iMac. Often, when I try to edit large strings of Mtext (which I use for specifications and general notes) the program drops the command, with the error message "Error occurred in mtext editor: MText parsing issue (#)". I didn't have this problem near as often in Bricscad v16, and I sometimes revert back to it to edit large areas of mtext, though I sometimes get the same message in v16 as well. Some of the mtext I use was created in Autocad before I began using Bricscad, so not sure if that has something to do with it, but I only have this problem on very long strings of mtext (usually multiple paragraphs long), not small single paragraph mtext. I'd like to find out what causes this problem and/or how to solve it, without having to explode the mtext. I'm not sure if this is still an issue in v18 and v19, but I have not upgraded yet due to the forum comments I've seen about frequent crashes on the newer platforms (I have an "all-in" maintenance agreement, so I could upgrade, but I like the stability of v17). I have attached a file with example mtext....one string I can edit in v17 and one (longer string) I cannot. On a related note, I noticed limited ability to change text colors within mtext in v17 (unless forced color is continuous) while this is not an issue in v16. Thank you.
Confirmed for V17. The issue has been fixed in V18.
Thank you, Roy. I look forward to this working better moving forward!
